Ford Edge 2009 Engine heats
Posted: 07/10/18
05:25 AM
chances are the radiator fan control module is bad..
i don't know if rockauto ships there..
https://www.rockauto.com/en/catalog/ford,2009,edge,3.5l+v6,1443379,cooling+system,radiator+fan+assembly,2181
with a WARNING..  there are 2 different Radiator fan assemblies..  and i don't know if they are INTERCHANGEABLE.
you can look at your radiator fan wiring carefully..  there are 2 fan motors..
if the wiring to the motors is in a TEE shape where both motors wiring joins and becomes a SINGLE PLUG into the module you DON'T have the TOWING OPTION
on the versions with a Tow package.. the wiring to Each fan goes thru individual harnesses to 2 different connectors on the radiator fan controller module..
there are a LOT of part numbers listed on the rock auto page.. you should be able to find something to fit..
import auto body parts suppliers sell them..
you can also tell if you have trailer tow package requiring the fan with 2 harnesses to the motors..  3 connectors total on the module..
look in the underhood fuse box..
if you have a 60Amp fuse in position F39  you DO NOT have the towing package..
if you have a 40AMP fuse in positions F39 and F40. you have the Towing package..
2018 Ford Edge
Below Average Below Average
