Please help tranny spraying fluid through inspection plate while runni
Posted: 06/27/18
12:27 AM
torque converters can spring leaks..
just because the front seal is soft does not mean its not damaged..
i have not been in the saturn automatic. but almost all have a front pump built in and several hydraulic control valves right in the pump body. this is transferred thru passages from the front pump to the main body..
Posted: 06/27/18
09:43 PM
yes..
the front pump is going to at least have a damaged front pump bushing..
perhaps damaged pump gears..
Posted: 06/27/18
09:43 PM
yes..
