Engine Hissing After Short Drive
Posted: 06/30/18
10:51 AM
hissing could be several things
are you loosing engine coolant??
do you have any vacuum leaks..
you could have a failed power brake  booster..  those will hiss..
you A/C system will hiss for 15 or 30 seconds after shut down as the high side pressure flows thru the filter orifice..
Posted: 06/30/18
09:19 PM
My car doesn't have air conditioning. It does have a ventilation/heating system. Does that count as an AC system?
nope..
once in a while. jeeps... will shut down and have a hissing noise thru the throttle body as the throttle is closed when the engine is shut off and the atmospheric pressure has to get in to fill the vacuum..
i have heard this from similar cars..  you might be hearing it thru the PCV elbow..
