Problem starting hot engine.
John Cunningham 68 John Cunningham 68
New User | Posts: 1 | Joined: 04/18
Posted: 04/26/18
09:20 PM
Hi There,first post on here.  I have a Vauxhall Combo 1.7 D Which starts perfectly first time every morning when engine is cold. If I switch engine off and start straight away, again no problem. However when the van has been sitting for about half an hour to an hour starting becomes a problem and the engine turns and turns for about 10 to 20 times before it fires, when it's doing this I turn the key to off wait a second and try again, which helps and will start after 4 or 5 turns which is still pretty sluggish. Any suggestions much appreciated.
Posted: 04/26/18
10:29 PM
Diesel hot start issues are way out of my range of knowledge..
you will want to carefully post year make model 1.7 Diesel extended cranking hot start in the title when you post this other site..
https://www.reddit.com/r/MechanicAdvice/new/
