Review Foxwell NT201 OBD II Auto Code Scanner for car
lingxiaozhu lingxiaozhu
New User | Posts: 1 | Joined: 12/17
Posted: 12/14/17
12:09 AM
OBD II Auto Code Scanner Automotive Diagnostic Scan Tool for car
71Krit8on4l
About this OBD II:
1.Foxwell NT201 obdii vehicle diagnostic code reader will work on standard OBD2/EOBD/JOBD & CAN domestic and import cars, light-duty truck (12v only), SUVs, mini-vans. European from 2000 year, US from 1996 year, Asian from 2008 year.TIPS: The scanner can not work on hybrid cars and electric cars.
2.This automotive scanner with unique one-click I/M readiness status design, which fast to scan vehicle’s engine healthy status. Red-Yellow-Green LED indicators allow you easily determine whether your vehicle meets the State Emission Monitor Status and assits you to pass the Smog Check.
3.The car computer diagnostic tester will read/erase engine fault codes and show the DTC definition on the screen. Quickly and efficiently troubleshoot the cause of check engine light and reset monitors. View Freeze Frame data. Show live data in the text and graph format.
4.Built in speaker and 2.4'TFT colorful LCD display screen provide visual and audible indication for readiness verification. Unique dust-resistant surface allows this auto code reader scanner more durable and stronger.
Posted: 12/14/17
01:24 AM
The Moderator took a quick look at this. its really NOT worth the money.
it only gives you codes and only works on 96 to 2008 models..  no hybrids  or electrics..
one cannot really diagnose anything by just looking at codes .  the codes send you to a page in the service manual. to follow the trouble shooting path.. not to replace the part listed in the trouble code.. you have to see what the sensor data is doing in a LIVE DATA STREAM .. and sometimes in a GRAPH Mode..
this only has the decent feature listed as number 2.. the red yellow green lights to tell you if there is a good chance of passing smog.
