How To, Caring for Tires
andrea.jule21 andrea.jule21
New User | Posts: 9 | Joined: 10/14
Posted: 03/22/15
06:41 AM
Before we get into how to care for a car tire we should first know the dangers of tire that never in check by its owner. Surely as a major component of car tires must be given special treatment in the treatment and should not be left without a check-up on his condition. Ban the condition of the elderly and unfit would be fatal to your car like an accident that could endanger your life. Ban the elderly or thin can be dangerous for the stability of your car and cause the car is not running properly. It is necessary for tips on caring for the right car tire so durable. Well here is the proper ways to take care of your tires:
Car Tire Air Pressure
How to care for the first car tire air pressure is noticed. Air pressure affects the long use of the tire. Tire pressure that is too small will make you tire easily damaged, while if your car tire pressure is too hard will make the tire easily torn and membayakan your safety because if exposed to too much heat friction tires could have exploded. For the tire pressure should be in accordance with the conditions of your trip in order to stay comfortable during the trip.
Spooring and Balancing
Then the second car care tips is noticed Spooring and Balancing. Spooring and Balancing is a way that you can do to maintain the stability of your car tires. Usually tires are often used to be quickly transformed into a less stable position for it every 5000km usage you are advised to do spooring and balancing to maintain the stability of your tires during driving.
Driving Good and True
Applying good driving behavior and can properly maintain the durability of tires you use. Examples of good driving behavior and correct as not changing drastically speed, no sudden braking, and remove items in the car that is not important that the burden is on the car is always awake. This behavior is proven to make tires more durable than usual.
driftinJ driftinJ
New User | Posts: 16 | Joined: 04/17
Posted: 04/18/17
12:55 AM
Good tips! I may add, if you got a spare tires of the same size, it is advisable to include it on the rotation. It will even out the worn among them.
Also observing the worn pattern and possible road noise will help any issues may occur and could give future damage.
Moderator | Posts: 2448 | Joined: 08/14
Posted: 04/18/17
12:04 PM
Before putting SPARE TIRES INTO USE. there is a DOT number on one side.. it is a specific serial number assigned to each tire..  check the DOT numbers against the DOT dot numbers web site..
you may need to NOT put it in if the production date is over 5 years old. or if it was recalled..
there were places that put spare tires from ford explorers back on the car..  the spare tires failed as they had been recalled and were over 10 some where 15 years old and the drivers and occupants were killed or injured when the spare tire failed and the explorer rolled over.
arhenry10 arhenry10
New User | Posts: 17 | Joined: 04/17
Posted: 04/18/17
11:07 PM
I think most drivers should keep this in mind. Although it may be seldom someone would use a spare tire, just a food for thought, this kind of information can come in handy in preventing such accident like the story you shared.
helen200791 helen200791
New User | Posts: 1 | Joined: 09/17
Posted: 09/22/17
01:12 AM
Anybody know these
edit removed...  spam.. from Ukraine (
CapriRacer CapriRacer
Enthusiast | Posts: 360 | Joined: 02/07
Posted: 09/22/17
03:38 AM
Those guys are based in Florida and FL is one of those areas of the country where I would recommend NOT buying used tires - unless the car is going to be sold or stored.
