03 Dodge caravan 3.8L tapping noise
bbuss2 bbuss2
User | Posts: 220 | Joined: 06/11
Posted: 08/04/12
11:38 AM
03 Caravan with tapping noise that sounds like valve tap or ratle noise
The van has about 150K on it
I had the front valve cover off and I don't think it's a valve tap
I'm thinking could it be the timing chain? Or does it have a belt?
My expertise is transmission, not general repair
Bob
Posted: 08/04/12
08:34 PM
some of the earlier motors had rocker arms that needed longer rocker arm bolts and deeper drill and tapping..
snap the rocker arm pedestal right off.. causing usually a dead cylinder...
what does the damper look like... i have run into a few that the rubber failed..
here is an article on rebuilding them .. i always find them enlightening..  i have not read this one..
http://www.enginebuildermag.com/Content/Site302/Articles/03_01_2010/7203433L38Lpdf_00000029832.pdf
exhaust leak from a cracked exhaust manifold..
loose spark plug..
bbuss2 bbuss2
Posted: 08/07/12
06:31 AM
Thanks wayne
