Earths Inner core question.Since the earth’s inner core has essentially zero gravity do to mass attraction being equal in all directions. When you throw in the earth’s rotation. I would think that there are actually negative forces in effect there. The superheated magma there will off gas toward the center causing a super pressurized ball of what is probably plasma do to the heat and pressure.This might be why the shockwaves reflect off the inner core and seem to travel around the outer boundary instead of passing through. Just like an inflated balloon.Proving the center is filled with some kind of gasses. Are you drinking a cup of coffee? Stir it really fast. Then pull the spoon out. Notice the rotation pulls the liquid away from the center leaving a depression in the surface of the coffee.Zero gravity at the inner core. When there is an equal amount of earths mass all the way around. It will cancel out any single direction of pull. The sun and moon may actually cause tidal surges in the molten magma surface around the gas at the center of the inner core.I wonder if the asteroid belt which was probably a planet as I recall. Had the tidal surge pulled too close to one side due to Jupiter’s or some other gravity field allowing the gas bubble to get off center and expanding causing the destruction of what was a planet.
Did You work in NASA. Get Best Texas protein feeders andTexas auto air conditioning repair services.
nope .. not nearly smart enough.. too many traumatic brain injuries when i was a kid.. only some of it works.
