Posted: 04/05/12 11:17 AM
Tuning up cars for top conditions can reduce petroleum expenses by having an efficient engine and extended car life span. A well maintained car does not gobble petrol easily and saves several cents or dollars that should go for other important necessity. The following are ways to care for a car.
* Check tire pressure. A deflating tire causes engine to use more petrol. * Flush radiator coolant to prevent corrosion and overheating. * Change oil regularly. This is done after the car had run for 7, 500 miles. Avoid skipping even a single oil change as this may cause serious engine trouble. A dipstick can indicate acceptable oil level and color. Yellow golden brown color indicates OK while dark color means “change oil now” * Visit authorized and licensed automotive shops. A car service center must be trustworthy and reliable business partner. There are numerous shops such as car auto starter problem houston *Reduce unnecessary load as car uses more fuel while running on heavy weight. *Reduce mileage by using shortcuts and cutting unnecessary trips *Check brake fluid level to prevent faulty brakes and accidents. *Use car air conditioner when necessary. *Check car battery for electrolyte levels and electrode contacts. A faulty battery can prevent car from starting. *Check radiator for carbon buildup. An opaque radiator means change is necessary. *Wash car regularly. Apply non corrosive cleaning detergents such as car shampoo. Buff car body with carnauba wax for shiny looking results. *Change car parts if necessary such spark plugs, timing belts, fuses, and air filter.
Posted: 04/19/12 09:53 PM
A frequent maintenance helps to increase the life of the vehicle and also requires less major vehicle repairs. A good condition vehicle helps to get a cheaper auto insurance as compare to the others. These points are very helpful for newly car owners like me. Thanks for sharing it with us.
http://www.globalcaradvice.com/body_by_make_model.php?MID=Suzuki
Posted: 04/30/12 05:44 AM
It would be nice if you do the regular oil and air check ups and make sure that the battery is charged enough and weekly maintenance would help you to avoid major problems
AC Compressor
mathew111
Posted: 05/09/12 05:51 AM
I have read this nice article about how to save the vehicle safe from storm - http://blog.elephant.com/post/2011/08/26/Tips-to-Keep-Your-Vehicle-Safe-in-the-Storm!.aspx
dpfocjack
Posted: 06/13/12 10:00 PM
If you maintain your car in a proper way then it increases the life of car and also its performance. For maintaining your car you should check the engine oil because it’s directly related to performance of car. For effective performance of the engine it is necessary that you keep on changing the engine oil at regular intervals such as in between 10 to 15 days. Second the brakes of cars are very important for security purpose. Third for high performance it is good to regularly check the electrical system of car as it good then it will definitely provide free driving and high level performance.
used renault clio for sale
Posted: 07/06/12 02:09 AM
Tires are a car’s only connection to the road, so making sure they are in good shape and properly inflated is essential for automotive safety, optimum driving performance and potential cost savings, including better fuel mileage. Albuquerque Auto Mechanics
Mesa Auto Repair Brake Repair San Antonio Transmission Repair Largo
henry.budd
Enthusiast
Posted: 07/10/12 11:04 PM
Useful tips...
www.newusedcarssacramento.com
Posted: 09/24/12 09:21 PM
JohnnyCurtis: Tuning up cars for top conditions can reduce petroleum expenses by having an efficient engine and extended car life span. A well maintained car does not gobble petrol easily and saves several cents or dollars that should go for other important necessity. The following are ways to care for a car.
Hey, thanks for the post! Really useful information about car tune-ups.
Car Repair Shop Toronto
Posted: 10/25/12 08:09 AM
Thanks Johnny Curtis for your comprehensive tips and advices. I would like to add a tip which is an additional tint for car window can reduce UV rays and heat from direct sunlight. More of that useful information at auto glass repair albuquerque
robb800m
Posted: 10/25/12 08:50 AM
Thanks for the tip on the insurance. I didn't know that. Ive actually been doing some of the repair and maintenance work myself. I work for an a tool company so I get good prices on anything I need. This is totally a shameless plug but seriously the company does have great prices. better than buying off the tool truck http://www.solycostacargo.com
mathew111
Posted: 12/28/12 04:43 AM
The great tips for vehicle maintenance are here http://autos.yahoo.com/maintain/repairqa/. Maintaing a vehicle properly will also help you in lowering your car insurance cost.
Tami.P6
Posted: 04/21/13 09:28 PM
You can look for more tips for car and vehicle maintenance in this link:
http://www.rd.com/advice/saving-money/74-car-care-tips-to-keep-your-automobile-in-topnotch-condition/
For any automative maintenance and repair. Go to marksoldtowne.com
Mark’s Old Towne Service, Inc. has been providing high quality fleet maintenance since 1983. At our state of the art truck service center, located in the heart of Anaheim right off the 55/57/91 freeways
Posted: 05/20/13 12:28 AM
It is a useful thread for all used and new car buyers. Everyone can follow some addition tips on vehicle maintenance like cleaning everything, fixing cockpit, checking electronics gadgets, clearing the lenses, painting vehicle body, revitalize the A/C, maintenance on exhaust system.
www.ronduprattford.com
