xcl123
Posted: 02/21/12 08:56 PM
If you struggle from the tee box and you want to be more accurate, then you need to give the Mizuno JPX 800 Irons a try.It not only help you square the club face at impact,but also allow you to get a higher ball flight and more distance.Let's look at it.
The JPX 800 Irons cheap price has an oversized 460cc clubhead, which is designed with a strategic internal weighting system for a greater vertical and horizontal moment of inertia. The head itself is made with a six-piece plasma welded design for added strength and stability upon address. The club is carefully weighted with a 10g back weight and 5g heel weight to further contributed to the moment of inertia and low center of gravity.
The 460cc Ti Construction features a six-piece plasma welded design, which provides an extremely solid feel and allows for precise center of gravity placement for a high launch with low spin. Combined with an internal five-gram heel weight that helps square the face at impact, the JPX 800 Irons will help you hit the ball longer and straighter than you ever have before.
By the way, I would like to recommend the new discount golf equipment, such as JPX 800 Fairway Woods,JPX 800 Driver and so on.
Posted: 02/23/12 08:08 AM
xcl123: If you struggle from the tee box and you want to be more accurate, then you need to give the Mizuno JPX 800 Irons a try.It not only help you square the club face at impact,but also allow you to get a higher ball flight and more distance.Let's look at it.
SDSD
Posted: 02/23/12 08:09 AM
I was recommended this blog by my cousin. I'm not sure whether this post is written by him as no one else know such detailed about my problem. You're incredible! Thanks Best Regards Richee Moore
<a href="http://www.ezdia.com/epad/2013-toyota-tundra-revie/7898/" target="_blank">Toyota Tundra</a>
