Posted: 04/30/12 12:14 PM
My main problem with this car just started yesterday- I was driving home and pushed down on the gas when my engine just revved but the car didn't accelerate. This happened a couple of times, I get no acceleration but the engine is still revving and the RPMs are going up; I also noticed my odometer is slower to react now. I'm scared to drive it as this might happen again, could I be looking at an expensive fix?
Another problem I'm having happened a few days ago, I started up my car in the morning and got this weird tapping sound coming from the glovebox area- I popped my hood with the engine running and it is definitely not an engine problem, it is only coming from the inside of the car. I messed with all of my air settings and that didn't change anything...I've had my SRS light on since I bought the car but I don't see how that could be related?
Any help, especially pertaining to the first question, would be so greatly appreciated. Thank you!
Posted: 04/30/12 02:29 PM
deselect the Overdrive button on the gear shift...
you probably have a transmission failure happening .. more to come when the transmission guys get a look at this thread..
Posted: 05/03/12 07:13 AM
Most probably you have problem with your red line indicator on your tachometer which indicates the RMPs.And you should probably go to high gear.
AC Compressor
| Buyer's Guide |
