2001 Chevrolet Suburban - Engine stops while driving!
madatchevy madatchevy
New User | Posts: 3 | Joined: 08/11
Posted: 08/16/11
10:25 AM
I own a 2001 Chevrolet Suburban ¾ 4x4 with about 88,000 miles on it's 8.1 L engine it.  About a week ago, I was driving down the road and it just shut off!  No power!  No power steering, no power brakes, no engine!  Thank goodness I was not on a busy highway!  A day later, it happened again!  Fortunately, I was, again, not a busy road.  I looked up the problem on the internet and suspected that it was the crankshaft position sensor.  I also found out that there is a recall for 2001 Suburbans for this very part!  I took it to the dealer and when they put in my VIN number, amazingly, my truck did not qualify for a free fix!  I have to PAY $450 to fix this part that is obviously a problem!  This part goes bad and you can DIE!  And you never know when it will start going bad! WHEN will it shut down the first time?  It's like Russian Roulette!  We own 3 Chevys and will NEVER buy another one!  I hope it was worth the $450 dollars they made to lose a customer for life!
Chevrolet Suburban Recalls
Suburban ENGINE AND ENGINE COOLING Recall – ID# 48094
Recall Date
NOV 07, 2007
Model Affected
2001 CHEVROLET SUBURBAN
Description
ON CERTAIN PICKUP TRUCKS EQUIPPED WITH AN 8.1L V8 ENGINE, THE CRANKSHAFT POSITION CAN OPERATE INTERMITTENTLY OR FAIL COMPLETELY. IF THE SENSOR OPERATES INTERMITTENTLY, THE SES LIGHT MAY ILLUMINATE AND THE VEHICLE MAY RUN ROUGH. THE ENGINE MAY STALL, AND IF SO, MAY RE-START IMMEDIATELY OR AFTER A COOL DOWN PERIOD.
Consequence
IF THE SENSOR BECOMES COMPLETELY INOPERATIVE, THE ENGINE WILL QUIT RUNNING AND WILL NOT RE-START. EITHER OF THESE FAILURES CAN INCREASE THE RISK OF A CRASH.
Remedy
DEALERS WILL REPLACE THE CRANKSHAFT POSITION SENSOR FREE OF CHARGE. THE RECALL BEGAN ON DECEMBER 18, 2007. OWNERS MAY CONTACT CHEVROLET AT 1-800-630-2438 AND GMC AT 1-866-996-9463.
Potential Units Affected
11974
Notes
GENERAL MOTORS CORP. 06083
Posted: 08/16/11
12:43 PM
i would call the phone number listed on the recall notice..    give them your vin number and the date of production  and see if your truck is really a match for the recall..
this is the crank position sensor..  does not look like its a 450 bucks job to replace it..
i will have to check the flat rate manual..   sounds kinda steep..  unless they spent a lot of diagnostic time..  as intermittents are hard to nail down..
i just had a 98 C2500 5.7 that died in the street like yours..    when i swapped a new 12 buck fuel pump relay in .. it now runs..   it should be running the fuel pump  on the oil pressure switch also.. i will look at that later this afternoon. when he brings it in..
2013 Chevrolet Suburban
Average
