shock absorbers on rear hatch door Nissan Quest
spindr4015 spindr4015
New User | Posts: 1 | Joined: 10/11
Posted: 10/09/11
07:02 AM
How do I change the shock absorbers on the rear hatch door on 2007 Nissan Quest?
Posted: 10/09/11
11:29 AM
i have  not changed them on a quest yet...
usually it takes two people..    one to hold and to move the door up and down slightly in the open position .. the other to either unlatch the end of the (as nissan calls it.. STAY ASSY-BACK DOOR)    then probably unscrew the captured ball end on the other end..    use extreme care that when you are starting the threads in the new one.. that you get them lined up straight. without weight on them so they go in without cross threading..  then latch the ball end in..
there are several ways to do it..
you also might want to check with nissan parts.. as the pricing i saw online.. might be significantly less than many parts stores..
i don't see them cataloged yet at least at AZ...  oe fit is usually better..
Lift Support is what they are called in parts stores
or Charged lift supports ...
strong arms is one brand that is also a noun used in describing them..
2013 Nissan Quest
Minivan/Van
Average
