PDF Editor Pro for Mac - Edit and Convert PDF as per your desires. OCR
brian17 brian17
New User | Posts: 13 | Joined: 02/11
Posted: 08/07/11
07:41 PM
PDF Editor Pro for Mac adds OCR technology and 6-in-1 PDF conversion functions on the basis of standard version. Pro version provides you a smarter way to deal with PDF documents.
   * Extract text from scanned PDF to make the content searchable and editable
   * Edit text, images directly within PDF files
   * Convert PDF files to Office documents, EPUB files, HTML pages and Text files
   * Add text, images, and signatures into PDF files
   * Add multiple annotations and comments on PDF files
   * Highlight, underline, and strike through text in PDF files
   * Reformat the layouts by drag-and-drop
Support OCR
   * Outstanding OCR accuracy and format preservation
   * OCR enables you to search, correct, and copy the text in a scanned or image PDF directly
   * Support 17 recognition languages: English, Turkish, Greek, German, French, Italian, Portuguese, Spanish, Russian, Polish, Czech, Slovak, Ukrainian, Bulgarian, Croatian, Romanian, and Catalan
Edit PDF Files
   * Add, modify or delete text in PDF files (support editing text only in English)
   * Drag and drop text block or images to change the layouts
   * Insert images or digital signature into PDF files (JPEG, PNG, TIF, and BMP)
   * Crop, resize, move, delete images in PDF files
   * Edit PDF bookmarks and properties
Export PDF to 6 popular document formats
   * Export PDF files to Word, Excel, PowerPoint, EPUB, HTML and Text
   * Preserve text, images, tables, columns, etc. after conversion
   * Support encrypted PDF file conversion
   * Support Microsoft Office for Mac 2008/2011
Annotate and Markup
   * Annotate with Sticky Note and Text Box to share comments
   * Add shape annotations, including Arrow, Line, Rectangle, Oval, Polygon, and Cloud
   * Add free-hand drawings with Pencil and Eraser
   * Edit inner links and hyperlinks in PDF files
   * Markup PDF text with text tools, including highlight, underline, and strikethrough
   * Allow you to customize: annotation color, markup color, line-thickness, line-style, etc.
Related tags:
pdf editor for mac; pdf converter for mac; edit PDF text;
edit images and graphics; edit properties of PDF files; perform OCR to scanned PDF files
brian17 brian17
Posted: 08/18/11
12:06 AM
PDF Converter for Mac is a nonsuch PDF tool to help Mac users convert PDF to Word documents(*.doc), Excel spreadsheets(*.xls), PowerPoint presentations(*.pptx), EPUB eBooks(*.epub), Text files(*.txt) and HTML pages(*.html). Mac users can choose any formats they need to convert to and all the conversion can be done within only one program.
With PDF Converter for Mac, you can:
   * Print restricted PDF files
   * Resize images of PDF files
   * Edit PDF files in Microsoft Office
   * Share PDF files on internet easily
   * Change contents in any existing PDF files
   * Modify typos and misspellings in PDF files
   * Calculate and edit data in Microsoft Excel
   * Read PDF eBooks on mobile devices, such as iPad, iPhone, iPod touch, Sony reader and more
   * Extract the text, images, graphics, tables and hyperlinks for reusing in other applications
[b]How to use this PDF Converter for Mac?[/b]
First download the PDF Converter for Mac and install it on your Mac.Then follow the 3 simple steps below to convert PDF files on Mac now:
Step1. Import PDF files
To import PDF files to convert, you just need to drag and drop PDF files to the panel. And also, you can choose "File -> Add PDF Files" in menu of the toolbar to add PDF files.
Step2. Choose the format to convert and customize your conversion
Click on the gear icon in the pop-up window, you can choose the output format: MS Office Word (.doc), MS Office Excel (.xls), MS Office PowerPoint (.pptx), HTML  Document (.html), Electronic Publication(.epub).
Step3. Start Converting
Click "Convert" button to convert PDF files. Each PDF file will be converted as the format you choose. After conversion, you can click the format icon to open the converted file.
Related tags: PDF Converter for Mac, PDF to Flash Converter for Mac; PDF to Word Mac, PDF to Excel Mac, PDF to PowerPoint Mac, PDF to HTML Mac, PDF to TEXT Mac, PDF to ePub Mac, PDF Password Remover, Remove PDF Password, unlock pdf password, pdf editor for mac, edit pdf files mac
brian17 brian17
Posted: 08/18/11
12:08 AM
AnyBizSoft PDF Password Remover for Mac is a small yet powerful PDF decryption tool on Mac OS X. It enables Mac users to remove copying and printing restrictions from encrypted PDF files. It's quick and easy-to-use. Batch decryption is supported.
Step 1 Import
Drag PDF files on your Mac and drop them into the panel. Or choose File-> Add PDF Files in the menu bar to add PDF files.
Note:
PDF Password Remover for Mac can decrypt PDF files with Owner Password directly without knowing the password. But if the PDF file is encrypted with User/Open Password, you need to unlock it before decryption. Otherwise descryption of the file will be skipped.
Actually even Acrobat also requires the password if you want to remove pdf password on mac from encrypted PDF files. And most PDF decryption tools on the market can't remove Open Password from PDF files even if you know the password. It's reasonable because the Open Password is set by authors to protect copyrights of their works. You can't get access to the file without permission.
If you have permission to get access to the file and want to remove the pdf password for easier reading, just click on the lock icon beside the PDF file and type correct password in the pop-up box to unlock the PDF file for decryption.
Step 2 Select an output folder
Choose PDF Password Remover-> Preferences... in the menu bar, you can select an output folder for the output files.
Step 3 Decrypt
Click Start button to decrypt the encrypted PDF files. The decryption will be finished in seconds. Then you can click on the PDF icon to open the restriction-free PDF files.
Related tags: PDF Converter Mac; PDF to ePub Mac; PDF to Word Converter; pdf password remover; pdf password removal; pdf password recovery; unlock pdf password; remove pdf password; lost pdf password; pdf password unlocker; pdf security software; pdf encryption software; pdf user password remover; password recovery software; pdf password remover software
michaelandy michaelandy
New User | Posts: 15 | Joined: 06/11
Posted: 09/23/11
06:03 AM
If you delete some important document or lost your precious family videos on your Mac, don't depressed any more! Here we will sincerely introduce the best Mac Data Recovery software – Wondershare http://www.pdf-converter-mac.com/data-recovery-for-mac.htmldata recovery for mac</a> to help you recover your deleted, formatted and lost data on Mac. With this best Mac Data Recovery Software, you can not onl y recover document, but also image, video, audio, Email and so on.
mac PDF converter| PowerPoint to YouTube
fess fess
New User | Posts: 2 | Joined: 10/11
Posted: 10/12/11
05:06 AM
interesting for me, thanks
naoyang naoyang
New User | Posts: 2 | Joined: 07/11
Posted: 10/18/11
02:38 AM
I recently found a very practical converter for ipad, previously, these converting problems were often bother to me, for the ipad only can support move file, mp4 and H.264 format, so how to convert dvd to ipad for mac this simple converting can not be finished. Now the Cucusoft iPad Converter Suite can help you. With it, you can convert almost all video formats to iPad video format, such asconvert avi to ipad and convert flv to ipad.
brian17 brian17
Posted: 11/30/11
07:09 PM
great for sharing such an useful program.
zyp0426 zyp0426
New User | Posts: 15 | Joined: 01/12
Posted: 01/18/12
01:24 AM
Mac DVD Copy is a powerful DVD copy software for Mac users, which helps copy DVD movie (D5 to D5, D9 to D9) with the entire movie in 1:1 ratio perfectly. It can also compress DVD-9 (dual-layer DVD) to one DVD-5 disc with high quality.
Worried about children scratching your favorite DVD movie disc? Want to play your treasured movie again and again without damage the original DVD disc? Try this powerful and handy Mac DVD Copy. It is able to copy DVD to DVD, you can choose to backup DVD to ISO file or DVD folder on your computer or directly burn DVD to a blank DVD disc.
Mac DVD Copy has an intuitive interface, it lets you copy DVD movies to new DVD disc or backup DVD to PC with a few clicks. And Mac DVD Copy does no harm to the original DVD disc. DVD copy Mac is such an tool that can copy DVD on Mac to DVD, to computers or to devices with perfect output quality and high speed. It can also compress DVD-9 (dual-layer DVD) to one DVD-5 disc. It is a very useful and convenient tool. Now let me give you a show of how to use DVD Copy Mac.
Here is a tutorial for you to learn step by step.
For preparation, you should free download a DVD Copy Mac and install it.
Step 1. Choose Output Methods
Launch DVD Copy Mac, there are three output destinations for you to copy DVD: Copy to DVD, Copy to Local or Copy to Devices.Here we Choose Copy to DVD as an example.
Step 2. Select the DVD files you want to copy. Then you enter into an interface.
Notice: we can have a preview of the videos by double click the video listed in the list pane and click Play button.
Step 3. Settings
You can choose to Full Copy or Main Movie Copy under Options. you can rename the video by typing text in the DVD Name box.
If you have multiple Hard Drives, select the one you want to use in the drop-down list of Burn Disc in. If you want to copy a D9 DVD to a D5 Disc, select D9 to D5 compression.
You can choose subtitles and audio tracks by selecting the options in the drop-down list of Subtitles and Audio.
Cick Back if you want to choose other output types.
Step 4. When all settings are done, click Start to begin coping.
Ok, we have finished the whole conversion. You can free download a DVD copy Mac and copy DVD on Mac right now!
(This article is an original from DVD Copy Mac, http://www.dvdcopymac.net)
MagCafekr MagCafekr
New User | Posts: 2 | Joined: 07/12
Posted: 07/05/12
12:33 AM
PDFpie PDF to PPT for Mac - Seamlessly Convert PDF to Editable PPT in Mac OS X
1. Quickly produce dynamic PowerPoint presentations from PDF slides
2. Preserve original text, images, graphics, tables, hyperlinks, layout and formatting
3. Convert encrypted PDF files to PowerPoint presentations on Mac
4. Support batch and partial conversion modes
PDF to PowerPoint for Mac is the first and best PDF tool for Mac users to efficiently convert PDF to PowerPoint. It enables users to make a dynamic PowerPoint presentation quickly and efficiently by recovering PowerPoint presentations from PDF slides.
related tags:
convert pdf to ppt
pdf to ppt mac
import pdf to ppt
unlock pdf
pdf unlocker
