5speed e47a-lb
aleutianwest59 aleutianwest59
New User | Posts: 1 | Joined: 05/11
Posted: 05/16/11
02:38 PM
Can i put the guts from as E47A-LB  into a e67A-FA body thanks bronco 2 1986 thanks for your time   wayde
Posted: 05/17/11
08:47 PM
The cluster shafts are the same part number but the input shafts and bearing kits are different part numbers.I would call the dealer and get the part number on both cases and see if they match.
http://www.drivetrain.com/parts_catalog/manual_transmission/what_ford_manual_transmission_is_in_my_vehicle.html
http://www.therangerstation.com/tech_library/pdf_documents/Mitsubishi5speed.pdf
