porjohn
Posted: 05/02/11 10:40 AM
I have had my 2006 Highlander Hybrid for 4 years now (79k miles) and have had no trouble with it until January of this year when the dashboard lit up like a Las Vegas casino and displayed "check hybrid system." I took it into the dealership and after 4 days they concluded that the battery (not the hybrid batteries) needed to be replaced as well as the connections to it. So be it. Back to normal. Skipping ahead to April, once again I win the Dashboard Jackpot and all the warning lights are lit up, the engine temp gauge doesn't work, the outside temp only reads E, and the only window that works is the driver's side. I once again took it back to the dealership where after two days they concluded that it was probably caused by a loose knob on my A/C control. They cleared the codes and things were back to normal... for 10 days. Yesterday, the exact same problem re-occured. Does anyone have any experience or information on this? It would be greatly appreciated.
Here are the codes that came up (in order on the report):
P3108, U0146, P3108-594, C1310, b1211, B1214, B1262, B1271, B1273, B1273, B1293, B1200, B1214, B1262, B1271, B1273
Here is a look at the dashboard casino:
Thank you!
john.
Posted: 05/02/11 03:18 PM
john... i am sorry.. i am not going to touch this one... i don't have the proper info to give you a good and proper answer...
spend the money on a FACTORY service manual... not a chiltons or haynes... the big thick one from the toyota dealer...
i see you posted codes... but.. are the codes current.. or are they what they fixed... so you will need to access fresh codes...
you have several choices in scan tools... a harbor freight 98614.. that will read the P0000 codes... but you are going to need to buy a professional model scan tool.. the least expensive model that will do it is the OTC 3499N... its a good deal and can be had for just under 500 bucks.. and will come in handy for years to come...
the trick about each code.. many times.. some data will be stored when the code set... so you can see what the car was doing at the time the code set... makes it much simpler to diagnose ..
i should inform you that.. many of those items are CAN (controller area network ) controlled.. where when you work a switch.. it sends a digital request to the PCM and the PCM thinks about it and sends a command out to the controller for that item...
there is just so much to know.. and so much to test... please DON"T go probing around...
one thing... has anybody installed any accessory... like an adaptor for the Ipod to play through the stereo system.. or for a cell phone through the onboard system.. an additional car alarm.. a remote starter system..
you will have to understand... everything is hooked together...
with a scan tool... i would start by looking at EVERY computer controlled circuit... verify that its working and properly responding... codes will point you to a section of the repair manual... follow instructions... working on hybrids also require you to get a proper set of insulated gloves.. there is enough voltage running around on some wires to KILL you instantly..
why do i ask... if you had anything installed... there are some jeeps running around that EVERYTHING inside the cabin quit working.. turned out to be a Ipod adaptor plugged into the back of the stereo...
sik1313
Posted: 01/25/12 04:15 PM
What fixed it? I have one with same problem! thanks
Posted: 01/25/12 08:11 PM
do check back... i will have a new source of info now... its going to take some research. can you post all the codes you get also... so i am not looking up the wrong info... and your exact year, model, engine.. 2 wheel drive or 4 wheel drive.
a few things...
can you identify everything in the truck that does NOT work.... like the guy above...
any item can wipe out the CAN system and cause all kinds of things to fail...
lets first look at the TSBs... not all will apply to every truck....
2006 Toyota Truck Highlander 4WD V6-3.3L (3MZ-FE) Hybrid Recall and Technical Service Bulletin Titles
TSB Number & Issue Date TSB Title SC-90L/B0A-INT FEB 11 Recall - Carpet/Floor Mat/Accelerator Pedal Interference SSC60F JUL 06 Recall - Carpet/Accelerator Pedal Interference
TSB Number & Issue Date TSB Title SSC90A JAN 09 Campaign - Electric Steering Gear Replacement
TSB Number & Issue Date TSB Title SB0006-11 JAN 11 A/T - World Standard Automatic Transmission Fluid CRIB180 DEC 10 Vehicle - Usage Of Non-OE Parts CRIB178 SEP 10 A/C - Special Electric A/C Compressor Refrigerant Oil SB0138-10R1 JUL 10 Drivetrain - ATF/Gear Oil leak From Transfer Case Vent SB0141-10 JUN 10 Body - Windshield/Back Glass Ticking Noise CRIB177 MAR 10 Restraints - OCS System Initialization SB0064-10 FEB 10 Engine Controls - Techstream(R) ECU Re-Flash Procedure SB0398-09 DEC 09 Engine Controls - A/F And O2 Sensor Identification SB0079-09R1 DEC 09 Vehicle - Long Term Storage Guidelines CRIB176 DEC 09 Body - Approved Collision Repair Methods CRIB175 DEC 09 Body - HSS/UHSS Cabin Reinforcement Repair/Replacement SB0301-08R1 OCT 09 Engine - Serial Number Locations/Identification SB0207-09 JUL 09 Electrical - Abnormal Low Pitched Horn Operation SB0288-08R1 JUN 09 Interior - Squeaking Noises From The Front Seat SB0131-09 APR 09 Ignition System - MIL ON/Ignition Coil DTC's Set CRIB173 APR 09 Paint - Refinishing Information CRIB165 MAR 09 Body - Acid Rain Paint Damage Prevention/Repair CRIB172 MAR 09 Body - Bumper Component Repair SB0062-09 FEB 09 Engine - Oil Leak From The Bell Housing Area SB0049-09 JAN 09 Body - Moonroof Auto-Close Function Inoperative SB0391-08 DEC 08 Steering/Suspension - Vehicle Pull Repair Supplement SB0386-08 DEC 08 Hybrid Systems - MIL ON/DTC P0A78/Info Codes 286/287 CRIB170 OCT 08 Body - Plastic Bumper Refinishing SB0296-08 SEP 08 Steering - Knock/Pop Noise When Turning Steering Wheel CRIB164 SEP 08 Vehicle - VIN Plate/Certification Label Replacement SB0144-08 JUL 08 Vehicle - Certification Label Information SB0138-08 JUL 08 Body/Frame - Protective Wax Coating Information CRIB167 JUL 08 Body/Interior - Trim Removal & Installation SB0053-08 MAY 08 A/T, M/T - Alignment Pin Service Precaution SB0038-08 APR 08 Engine - Cylinder Head Cover Baffle Precautions SB0036-08 APR 08 Lighting - Headlamp Lens Discoloration SB0020-08 MAR 08 ABS/TCS - Zero Point Calibration Information CRIB163 FEB 08 Body - Sealing Hem-Flanges & Body Seams CRIB161 JAN 08 Body - Collision Damage Repair Precautions CRIB159 DEC 07 Body - Corrosion Prevention & Sound Absorption Info. CRIB160 DEC 07 Restraints - SRS Service Precautions PG007-07 NOV 07 Vehicle - Replacement VIN Plate Information EL010R-07 NOV 07 Keyless Entry - Remote Transmitter Programming Guide BR008-07 NOV 07 Brakes - Squawk/Chirp/Honk Noise Upon Pedal Application EL009-07 NOV 07 Keyless Entry - Programming Remote Transmitters CRIB158 OCT 07 Body - Panel Adhesive Information SS006-07 AUG 07 Battery - Absorbed Glass Mat Battery (AGM) Information SS004-07 AUG 07 Restraints - SRS Component Disposal CRIB155 AUG 07 Body/Frame - Sectioning Information CRIB156 AUG 07 Electrical - SRS And HV Wiring Repairs EG030R-07 JUL 07 Engine Controls - Highway Speed Rocking Sensation EG057R-06 JUL 07 Engine Controls - Rocking Feeling at 40 MPH PG003-07 JUL 07 Hybrid Systems - Emergency Response Training CD EG034-07 JUN 07 Engine Controls - Bank 1/Bank 2 O2 Sensor identification TC008-07 JUN 07 Drivetrain - Fluid Leaks From Transfer Case Vent BO013R-05 MAR 07 Restraints - Seat Belt Extenders TC003-07 MAR 07 Drivetrain - Drive/Axle Shaft Replacement Precautions AU001R-06 FEB 07 Audio System - Quick Reference Diagnostic Guide TC012R-06 FEB 07 A/T - Identification/Serial Number Location EL003-07 FEB 07 Air Bag Systems - Repair Manual Supplement PA001-07 JAN 07 Body - Replacement Bumper Cover Refinishing BR012-06 DEC 06 Brakes - MIL On/DTCs C1341-C1344 After Pad Replacement PG001R-06 NOV 06 Electrical - Battery Maintenance and Testing BR009-06 OCT 06 Brakes - Alternative Brake Pads Available SU007-06 OCT 06 Suspension - Shock Absorber Replacement Criteria CRIB146 SEP 06 Body - Paintless Dent Repair Information PG002-06 JUL 06 Hybrid System - Inverter Removal/Installation Precaution PG011R-05 JUN 06 Fuel System - Fuel Injector Cleaning Procedure BO017R-03 APR 06 Body - Interior Trim Panels/Garnish Loose EG018-06 MAR 06 Engine Lubrication - ILSAC GF-4 Oil Recommendations EG017-06 MAR 06 Hybrid Systems - MIL ON/DTC P0A7A/Info Code 325 EG026R-05 FEB 06 Engine Controls - ISC Learn procedure EG001R-06 JAN 06 Engine - ILSAC GF-4 Engine Oil Standard BO016-05 DEC 05 Body - Front Door Weatherstrip Comes Loose SS003-05 NOV 05 Audio System - CD Player Skip Verification EG052-05 NOV 05 Engine Controls - MIL ON/DTC's P0171/P0174/P2195/P2197 BO014-05 NOV 05 SRS/Interior - Seat Cover Replacement Caution PA002R-02 OCT 05 Paint - Paint Stains Under Rapgard BR004R-05 OCT 05 Brakes - Front Brake Squealing Noise SS003R-02 AUG 05 Antitheft - Diagnostic Tester Immobilizer Function EG045R-04 JUN 05 Engine Controls - Entering VIN When Replacing PCM/ECM PD016-05 APR 05 Battery - HV/Auxiliary Battery Maintenance BO006-05 MAR 05 Restraints - Seat Belt Extender Availability PD013-05 MAR 05 Instruments - Compass Calibration Procedure CRIB122 FEB 03 Body - Body Sectioning
Posted: 01/25/12 08:31 PM
Definition of Diagnostic Trouble Code B1200 Toyota: Normal
Definition of Diagnostic Trouble Code B1211 Toyota: Driver door ECU communication stop
Definition of Diagnostic Trouble Code B1214 Toyota: Door system communication bus malfunction (+B short)
Definition of Diagnostic Trouble Code B1262 Toyota: A/C ECU communication stop
Definition of Diagnostic Trouble Code B1271 Toyota: Combination meter ECU communication stop
Definition of Diagnostic Trouble Code B1273 Toyota: Sliding roof ECU communication stop
Definition of Diagnostic Trouble Code B1293 Toyota: Gateway ECU(AVC-LAN adapter) communication stop
Definition of Diagnostic Trouble Code C1310 Toyota: Malfunction in HV system
Definition of Diagnostic Trouble Code P3108 Toyota: Communication malfunction (Engine -; HV)
Definition of Diagnostic Trouble Code U0146 Category Network Definition Lost Communication With Gateway "A"
so please post your EXACT CODES
the trouble shooting charts need to be examined for circuits that connect..
sik1313
Posted: 01/29/12 08:14 PM
They are the exact codes from first post to a tee! All symptoms exact! Almost same milage! It is a 2006 highlander hybrid 6 cylinder. Thanks!!!
sik1313
Posted: 01/29/12 08:17 PM
4x4!
Posted: 01/30/12 08:40 AM
this is going to require an advanced scan tool... to properly communicate with the CAN system and to monitor the various individual systems..
most scan tools are designed and programmed to work with the engine and transmission controls.. others with the antilock brakes. then air bags...
you are also going to need access to an online repair info site...
either
eautorepair dot net
or
alldatadiy dot com
both have the repair info for each trouble code..
reading all the TSBs.. not just the titles that might have something to do with this problem.. i saw several that i would want to read..
i do this for free.. so i cannot afford to purchase subscriptions to info sites for research ...
i have a few questions.. was anything modified lately..
like a new car stereo.. an IPOD adaptor installed into the radio wiring?????
because the CAN system runs many things on the car...
you could have a SINGLE item failure and cause all your problems..
so with a scan tool and the proper info... you test each device and monitor it with the scan tool.. to verify the failure or non failure...
warning.. you will also need a LOGIC PROBE... harbor freight sells these for under 20 bucks.. do NOT use a conventional test light.. you can damage the devices..
let me explain..
when you push a button.. you send a request from that switch to the computer .. the computer decides if it can operate the device you have requested.. so it sends a digital signal to that device... but there are only 4 wires running from part to part to part... ground.. power.. data high and data low..
if one switch is sending the wrong data stream.. or shorted out some how.. you can block the signals to the entire circuit..
sik1313
Posted: 01/30/12 04:37 PM
Well the car sat in the garage all weekend and cleared codes....problem went away! problem started day after snow. thought is water intrusion in vehichle somehere and from being in heated garage it may have dried!?! will let you know if returns when it rains or snows! thank you for your help!!!
| Buyer's Guide |
