Removing door panel from 2003 Tahoe?
oc65 oc65
New User | Posts: 1 | Joined: 02/06
Posted: 02/21/06
10:48 PM
Anyone know the easiest way to remove the passenger side door panel of a 2003 Chevy Tahoe?
dde123 dde123
New User | Posts: 21 | Joined: 07/06
Posted: 07/21/06
06:59 AM
go to your parts store and get a tool for removing door panels. you stick it up under the panel being very carful because everything on that panel is plastic. you should have at least 8 plastic clips that attact to your door panel that pop into a hole in your door. so you slide it along till you find one then pop it out . go all around the the door edge. then you should have a couple of screws that hold your arm rest to the door and maybe even a couple around the edge. take these out. when at the parts house they will also have a tool to go behind the window crank to get the clip off of that. It may also have a screw in the window crank too. but be very careful, because like I said everything is plastic and you dont want to break anything.  dave
2018 Chevrolet Tahoe
