2000 Ford Escort ZX2 Timing
justinpratt1085 justinpratt1085
New User | Posts: 1 | Joined: 11/09
Posted: 11/17/09
11:07 AM
Does anyone know how to time a 2000 Ford Escort ZX2 DOHC? I can't find the marks on th e camshafts.
Posted: 11/17/09
08:43 PM
there are none....     you have to pull the valve cover and lock the ends of the cams with a cam tool kit..
there are also no key ways in the cam sprockets or on the ends of the cams..  only a slot in the rear...
i have changed the timing belts without loosing the cam timing..  by carefully using a pair of fender washers and a 2 inch long bolt with a wing nut...    (fender washers are large diameter)     you can gently use a washer at the top of the bolt.. one and the threaded end.. with the wing nut at the bottom..   you can keep the cams from turning by gently locking the sprockets with the washers wedged above the center and below the center... DO NOT DENT the sprockets with the washers...
the reason you have to hold them with a pair of washers on a bolt... proper alignment will have the valve springs move one of the cams slightly... there is nothing you can do but hold it..
some tool rental stores will have a cam timing set for rent..
somebody posted the instructions
http://wiki.answers.com/Q/How_do_you_set_the_timing_belt_on_an_2-liter_Zetec_engine
this is what the ford tools look like...
http://www.usatoolwarehouse.com/usatoolwarehouse/OTC-6486.html
there are several versions of this tool.....
http://www.gates.com/common/images/Gates/ezlit/MultiLockTool.jpg
it locks the sprockets in place like the pair of washers on a bolt... so you can take the belt off without loosing the cam timing..   as long as you don't loosen the sprockets...
i have not measured the long bar above for dimensions    you might be able to use something else and shim it up with feeler gauges..   if you have to take the sprockets off... i would hold the cam up close to the sprocket if possible.. so you don't bend it..  you might also use a torque wrench to retighten the cam bolts..
Posted: 11/18/09
07:03 AM
send me a PM ...I'll send you what you need.
danchi danchi
New User | Posts: 3 | Joined: 01/10
Posted: 01/06/10
09:28 AM
I need those diagrams too...
Posted: 01/06/10
02:14 PM
i guess that you missed the other post...
autozone.com has it..  for free.. just join.. for free... log in.. ... select your car...     once you do that..  you will see a link to the repair info... look in the engine section... its there...
there is just too much information to post... since links don't show up.
autozone.com
REPAIR INFO  2001 FORD ESCORT ZX2 2.0L MFI DOHC 4CYL REPAIR GUIDE
ENGINE MECHANICAL
ENGINE MECHANICAL COMPONENTS
TIMING BELT
Escort, XZ2 (2000-2003)
Posted: 01/07/10
07:57 AM
I checked the links listed above and If you need the "proper " procedure and diagrams post your email address and i will send you what you need!
