91 dodge dynasty automatic transmission problem
joseb. joseb.
New User | Posts: 2 | Joined: 03/08
Posted: 03/26/08
03:28 PM
I have a 1991 dodge dynasty 3.3l v6 w. automatic transmission. I have noticed that it had been leaking tranny fluid I tried quick remedy additives and sealers but worked for only a while, a week ago I was driving to work and when I gave it gas the engine reved but the car wouldn't move, I checked the transmission fluid it was low so I filled it, and tried again but the problem remains. the only way it will move is if I over rev the engine but even then it barely crawls. I'm on a tight budget, if anyone can give me any insight to this problem, or where I can get it tempororly fixed for cheap it would be appreciated, thanks joseb.
edbd 4 Jesus edbd 4 Jesus
User | Posts: 54 | Joined: 02/08
Posted: 03/26/08
03:50 PM
we don't even know what state you are in... and a 91 dynasty is a throw away car, unless you want to restore it. another option is buy a used unit and pay someone to r&r it. hope it helps.
ASE/ATRA MASTERS REC/EXP, OEM, ATC AUTO DEGREE
