1 |  2 |  3 |  Next   | Last
How do I time the camshafts in a 2000 ford escort zx2 2.0 L dohc engin
garyrb garyrb
New User | Posts: 2 | Joined: 11/07
Posted: 11/10/07
06:47 PM
replacing the timing belt and the camshafts are out of time. Manual shows a camshaft alignment bar on back side of cams but it seems this could leave one or both of the cams 180 degrees out. I must be missing something Please help. Thanks in advance.
gary
Posted: 11/10/07
07:35 PM
There is an aditional tool that you need , it is a TDC timing peg.And the cam has 2 notches on them, use the second one indexed to the lower cylinderblock.Install the timing peg roll the cam ao it stops against the peg and install the alignment tool on the exhaust cam first.
What manual are you useing? Please don't tell me Chilton or Haynes or Mitchel.
If you need the right and full procedure I can email them to you.I have done 7 or 8 of these and after the first one it is realy easy, with the right tools.
garyrb garyrb
Posted: 11/10/07
10:04 PM
Wow, Thanks so much for the quick response. I need to have this ready for a friend by Monday AM. Sorry to say i am using the Mitchell OnDemand software and its not very clear. Unable to locate the hole for the timing peg on the block, or tell the exact position of the cams.
Sure wish i had your expertise behind me right now.
Thanks again for your help and please feel free to email me at gary9857@sbcglobal.net
Posted: 11/11/07
07:53 AM
The e-mails are on there way..I think these will be alot better for you.
tor429 tor429
New User | Posts: 1 | Joined: 12/07
Posted: 12/03/07
03:54 PM
need some help i have a 98 ford zx2 2.0L Zetec engine cant seem to get the timing right im using a haynes book and i cant figure out were the timing peg goes. Do i need to losen the gears on the cams if so do u know the tool i need for that. can u send me the full procedure also my email is tor429@comcast.net Thanks
Posted: 12/03/07
04:15 PM
Yes I can do thet.    Look for them in your e-mail ..
newman771 newman771
Posted: 12/22/07
10:58 AM
Good morning
I to am replaceing the timing belt on my z-x2 1998  DOC
could I also get a copy??
send to altd66@aol.com
Thanks in advance
specialist specialist
New User | Posts: 1 | Joined: 02/08
Posted: 02/15/08
07:50 PM
Hi sir,i am having the same problem with my ford.need illustration on how to set the timing.email is vwspec@hotmail.com
ickes24 ickes24
Posted: 02/21/08
07:13 PM
can i also get a copy of those directions, ickesdj@email.uc.edu
PLEASE AND THANKS!!!!!!!1
Posted: 02/21/08
09:16 PM
http://www.autozone.com/az/cds/en_us/0900823d/80/13/b1/0d/0900823d8013b10d/repairInfoPages.htm
Try this link it covers the 1.8  the 1.9 the 2.0 and the ZX 2.0 Hope this helps..
sandtrix07 sandtrix07
New User | Posts: 2 | Joined: 04/08
Posted: 04/20/08
08:13 AM
Hi
Im running into the same problem and I am trying to use a chilton manual Its not my car and thats the manual they have If you could email me the procedure it would really help again thanks for your help. email is dgkush@cox.net
Greg
Posted: 04/20/08
09:16 AM
A chilton??? you might as well not have anything...
Try this link if it dosen't help you , let me know.
gconnor3 gconnor3
New User | Posts: 1 | Joined: 05/08
Posted: 05/11/08
10:17 AM
where is the hole for the peg?  camshaft or crankshaft? if camshaft, front (gear) or back (where the alignment tool fits into the slots)
I just spun the intake cam lobes just past intake and the exhaust approaching open . . then aligned the slots horizontally...  is that not a solution
Posted: 05/11/08
11:51 AM
The crankshaft TDC peg hole is located on the outside of the block just behind the crank sensor connector.
harley4141 harley4141
New User | Posts: 1 | Joined: 03/09
Posted: 03/12/09
03:52 PM
Is it possible that you could email information on realigning of the cams and setting the cams to the correct position of a 98 ford escort 2.0 ztec motor.  I just changed the oil control solenoid.
