E4OD Will Not Shift PROBLEMS
cappyd892 cappyd892
New User | Posts: 3 | Joined: 10/07
Posted: 10/24/07
06:34 PM
Hi  I have a 1992 Ford F250 7.3 Diesel with an E40D transmission that wont shift.  When I put it in reverse it goes right into reverse and when I put it in drive it goes right into drive.  When I take off in drive it does not shift into second.  If I manually put it into second it goes into second but will not shift into third.  I can only manually shift between first and second.  I took the magnetic sensor off the rear end and it looks OK and I removed the wiring harness and the wires and connectors look OK.  Can someone please tell me where to start???   I thought that the kickdown cable was stuck but I understand that this tranny is all electronic.  Any suggestions???
1992 Ford F-250 7.3L Diesel, 10" SkyJacker LiftKit, 39.5" SuperSwampers, 6" Peterbuildt Stacks, Hypermaxx Turbo Kit.
