What is an Intake Manifold? A definition...
Balboa455 Balboa455
User | Posts: 69 | Joined: 05/07
Posted: 06/12/07
08:16 AM
This is just in case you ever have a problem with one. I was a service advisor and I was always explaining what this actually was...
Definition: The network of passages that direct air or air-fuel mixture from the throttle body to the intake ports in the cylinder head. The flow typically proceeds from the throttle body into a chamber called the plenum, which in turn feeds individual tubes, called runners, leading to each intake port. Engine breathing is enhanced if the intake manifold is configured to optimize the pressure pulses in the intake system
fromt about.com  Cool
