4T40E tranny problems
jjp53 jjp53
New User | Posts: 1 | Joined: 03/07
Posted: 03/25/07
06:10 PM
I'm working on a 2000 caviler. The car started off shifting only into 2nd gear no higher. it had a shift solinoid code.  changed the fluid filter and shift solinoids, and after it put back together it was in 1st gear no matter where the gear selector was (park, reverse, neutral, drive, 3rd, 2nd, or 1st).  Checked wiring to make sure nothing was left unplugged. The trans will now do nothing.  anyone have any ideas? trash it and buy another?
Hog Rider Hog Rider
Enthusiast | Posts: 275 | Joined: 02/07
Posted: 03/26/07
03:07 PM
With the transmission   in first  in park   as you stated  This is not good !!!  Sounds like the foward clutch pack  or planets are welded together !  ( Bound from Failure )  what was your Vehicle doing prior to this  failure ? Confused
Hog Rider
