1 |  2 |  3 |  Next   | Last
Sticky Thread
Please post your question or problem in one section only
Guru | Posts: 1019 | Joined: 03/06
Posted: 06/05/06
05:12 AM
I have noticed that people will post their problem in multiple sections of the Maintenance and Repair forums (a.k.a. "reposts").  Your questions will be seen just as many times if only posted in one section as i'm sure that most people who look in the Maintenance and Repair forums, look at all sections (auto maintenance, engine, transmission, etc.)
Thanks.
John
thodaiuy thodaiuy
New User | Posts: 2 | Joined: 09/06
Posted: 09/11/06
03:35 PM
what is code P0031 and C1201 Lexus LS430 year 2004 how do repair it help me
Johns Camry Johns Camry
New User | Posts: 1 | Joined: 11/06
Posted: 11/10/06
04:25 AM
My 1995 toyota camry xle  driver window will not close all the way.  it satys open about a half an inch from the top.  the window works it just does not close all the way.  i think it might be the window motor.
qtyfuzz qtyfuzz
New User | Posts: 2 | Joined: 11/06
Posted: 11/16/06
12:30 PM
thodaiuy:
i want to get to the segment discussing "water leak" to front floor of vehicle.  help, please.
ssimp ssimp
Posted: 11/17/06
07:38 AM
1994 Honda Accord brake lights out. Bulbs good and fuse is good. What would be the next thing to check?
bijan666 bijan666
New User | Posts: 4 | Joined: 11/06
Posted: 11/20/06
07:49 AM
The most likely cause of your problem is a piece of dirt or foreign
 object ( maybe a piece of broken glass )lodged in the tracks
 that guides the glass, checked the tracks and clean if necessary
  do not operate your power window until uou find the problem ,
  cause you window will shatter .
glennkawesch glennkawesch
New User | Posts: 5 | Joined: 12/06
Posted: 12/14/06
04:38 AM
I think it might be the motor as well.
Glenn Kawesch
mrcolt mrcolt
New User | Posts: 2 | Joined: 02/07
Posted: 02/24/07
11:02 AM
thodaiuy:
You can search a database of technical service bulletins for your vehicle's problem at http://www.iamsam.com/tsb.aspx
angelfast angelfast
New User | Posts: 9 | Joined: 06/07
Posted: 08/22/07
09:15 PM
I have a problem with my Saab Power Steering Pump...It seems that it has turned very hard to manipulate every time I change direction...Any ideas please?Thanks...
bww48 bww48
New User | Posts: 1 | Joined: 09/07
Posted: 09/04/07
08:30 AM
I have a 2000 Jeep Cherokee that has a weird electrical problem.  When the Auto headlight switch is on the lights occasionally will turn on during the day when the steering wheel is turned and even when the car is in the garage.  I recently also discovered that the left brake light goes out when the headlights are on and when the brake pedal is depressed. I have checked all the lights and they are all good.  Any ideas?
discer discer
New User | Posts: 1 | Joined: 10/07
Posted: 10/31/07
11:07 AM
I have a question regarding catalytic converters. What is meant when it says with air tube or without air tube on a converter?
delaneyj delaneyj
New User | Posts: 7 | Joined: 12/07
Posted: 12/07/07
10:53 AM
1995 gmc sonoma electrical draw of 5.5 volts draining battery,any imput
would be helpful
sxtstratus05 sxtstratus05
New User | Posts: 1 | Joined: 03/08
Posted: 03/20/08
09:58 AM
My girlfriend has a 2005 dodge stratus sxt sedan and her gas milage has been really bad lately...I figured maybe a tune up so I changed the plugs and wires and air filter so far and it didnt help...I can't think of any other reason why the milage would be soo poor.Any help at all would be great,thanks.
Glenhandy Glenhandy
New User | Posts: 1 | Joined: 04/08
Posted: 04/26/08
12:20 PM
I Have a1993 Nissan Extended Cab Truck, does anybody know the towing capacity of the vehicle It has a 2400cc motor with Automatic transmission.
Renae4. Renae4.
New User | Posts: 1 | Joined: 05/08
Posted: 05/01/08
12:03 PM
Help!! My 2000 Kia Sephia has been driving fine the past few months until last week it was totally dead. so i had a friend jump it, took it in and checked the charging system and they said it was fine once they replaced the battery. well, it drove around great all day but a day later it's dead again! they said everything was strong when they checked it w/a new battery so how could it be dead again? alternator maybe?
