1999 Nissan Quest that Overheats
mdkoh mdkoh
New User | Posts: 4 | Joined: 05/06
Posted: 05/28/06
02:29 PM
About 3 weeks ago the radiator fan bellied up in my 1999 Nissan Quest. After replacing the radiator fan asembly we discovered that the radiator fan motor did not function. Further inspection found the 15 amp fuse had blown opening the circuit. After replacing the fuse the fan rotated and appeared to function normaly. Now here is the problem, as long as we are running at a normal speeds without the air conditioner on everything functions properly. If the air conditioner is turned on the car begins to over heat nothing can be done to stop it unless you pull over and allow it to cool down normally.
I have reset the computer, thinking a line spike, when the fuse blew, may have scrambled the programming. What appears to happen is the fan runs at one speed but when it gets hotter than normal the fan shuts off. I believe this is a multi speed fan but unsure of how it works. Any suggestions or help in correcting this problem would be appreciated.
ADNOH ADNOH
New User | Posts: 43 | Joined: 04/06
Posted: 05/29/06
08:12 AM
It sounds like your thermostat switch is failing on you. The fan shouldn't shut off at a higher temp unless the high speed side of the switch was shorted out when the fuse blew. Plus I'm not 100% sure it's a two pole switch. You replaced the fan so I doubt the high speed side is bad but, new doesn't mean that much with auto parts. My money is on the thermostat switch. Hope this helps
Johnswiftm Johnswiftm
Enthusiast | Posts: 658 | Joined: 07/05
Posted: 05/29/06
11:33 AM
When the ac is engaged the fan should automatically come on check your relays.
mdkoh mdkoh
Posted: 06/04/06
08:08 AM
Thanks to you guys. I took a chance and purchased a relay (dealer only had one) and found that everything worked fine once I replace the H2 relay. It was burnt pretty good on the inside. So far we have not had an overheat problem and the fan speed schanges when the compressor kicks in. Thanks again for your help.
