Hello,Problem:Passenger head lights are dim. When on highbeam they turn off.Tried:Replaced every exterior light. Checked fuses. Checked connections.Any help is appreciated,Thank You
I had a similar problem with my newer corolla....im not 100% where the fuse box would be located on the 94 but if you look at the fuse for the headlights there is a small metal piece that the fuse attaches to...this piece came loose on mine and caused it to stay dim because of the loose connection...i dono what else to tell you :-p hope it helps
