FUSE location or Diagram - 05 VW passat - rear accesory outlet
outtie outtie
New User | Posts: 1 | Joined: 09/06
Posted: 09/09/06
10:13 AM
Hi - New here... I had to fix the rear seat accessory outlet assembly. It was working before I re-assembled everything... so I am assuming a fuse has blown... somewhere. I have checked and pulled every fuse in the drivers side panel. Could not find the location labeled for the accesory outlet. Any help would be greatly appreciated.
You may be asking why fix it if it ain't broke... the assembly was loose and the arm rest guides (under the center console) were catching on it. The assembly had popped lose and apart from one another but the current was live before I started.
