rkoehler
Posted: 08/27/06 03:58 AM
I have had my front wheels aliened twice, balanced, and rotated. Both garages stated that the front wheels are in spec. Still the front end pulls to the right. Nobody seems to know what is wrong. HELP!
Posted: 08/31/06 04:52 AM
have them check for bent suspension components.
aquabat911
Enthusiast
Posted: 08/31/06 05:16 AM
were the tires rotated just front to back or did they switch sides too? If just front to back, then try side to side and see if the vehicle pulls in the oppsite direction.
You said you just had the front tires aligned. Did they even check the rear end? It seems like a lot of cars now have no adjustment in the rear end, but if your front end isn't aligned with respect ot the rear the car will not drive straight.
You can also check for a dragging brake or bent or worn suspension components as JTM said.
Posted: 10/06/06 12:38 PM
post your specs from 1
